Hello!
First of all I just want to thank you guys for all the previous help you have been. What a great resource.
The project that I am working on involves using a PS5 controller to control 2x MCP4725 0-10V DAC as well as one MCP23017 all connected using I2C. It is all functioning right now however every once in a while we will get an error on the python script that reads as follows:
File “/home/pi/PS5Final2.py”, line 217, in
mcp23017.set_gpio_high(2, 1)
File “/home/pi/mcp23017.py”, line 98 in set_gpio_high
status = self.get_gpio_bank_status(bank)
File “/home/pi/mcp23017.py”, line 166, in get_gpio_bank_status
return self.smbus.read_byte_data(self.address, MCP23017_REG_GPIOA+bank-1)
OSEError: [Errno 121] Remote I/O error
Is this some sort of bandwidth error regarding either the MCP23017 card or the I2C connection? Any input or potential fixes would be greatly appreciated!
Nothing usual just PLC inputs. It seems to happen periodically throughout use when multiple button inputs are being used. My concern is that there is too much information being passed and it is causing an error. I have tried adding small delays between inputs but it still seems to happen.
MCP23017_IODIR_PIN_7_INPUT = 0x80 # Pin-7 is configured as an input
MCP23017_IODIR_PIN_6_INPUT = 0x40 # Pin-6 is configured as an input
MCP23017_IODIR_PIN_5_INPUT = 0x20 # Pin-5 is configured as an input
MCP23017_IODIR_PIN_4_INPUT = 0x10 # Pin-4 is configured as an input
MCP23017_IODIR_PIN_3_INPUT = 0x08 # Pin-3 is configured as an input
MCP23017_IODIR_PIN_2_INPUT = 0x04 # Pin-2 is configured as an input
MCP23017_IODIR_PIN_1_INPUT = 0x02 # Pin-1 is configured as an input
MCP23017_IODIR_PIN_0_INPUT = 0x01 # Pin-0 is configured as an input
MCP23017_IODIR_PIN_INPUT = 0xFF # All Pins are configured as an input
MCP23017_IODIR_PIN_OUTPUT = 0x00 # All Pins are configured as an output
MCP23017 Pull-Up Resistor Register Configuration
MCP23017_GPPU_PIN_7_EN = 0x80 # Pull-up enabled on Pin-7
MCP23017_GPPU_PIN_6_EN = 0x40 # Pull-up enabled on Pin-6
MCP23017_GPPU_PIN_5_EN = 0x20 # Pull-up enabled on Pin-5
MCP23017_GPPU_PIN_4_EN = 0x10 # Pull-up enabled on Pin-4
MCP23017_GPPU_PIN_3_EN = 0x08 # Pull-up enabled on Pin-3
MCP23017_GPPU_PIN_2_EN = 0x04 # Pull-up enabled on Pin-2
MCP23017_GPPU_PIN_1_EN = 0x02 # Pull-up enabled on Pin-1
MCP23017_GPPU_PIN_0_EN = 0x01 # Pull-up enabled on Pin-0
MCP23017_GPPU_PIN_EN = 0xFF # Pull-up enabled on All Pins
MCP23017_GPPU_PIN_DS = 0x00 # Pull-up disabled on All Pins
MCP23017 General Purpose I/O Port Register
MCP23017_GPIO_PIN_7_HIGH = 0x80 # Logic-high on Pin-7
MCP23017_GPIO_PIN_6_HIGH = 0x40 # Logic-high on Pin-6
MCP23017_GPIO_PIN_5_HIGH = 0x20 # Logic-high on Pin-5
MCP23017_GPIO_PIN_4_HIGH = 0x10 # Logic-high on Pin-4
MCP23017_GPIO_PIN_3_HIGH = 0x08 # Logic-high on Pin-3
MCP23017_GPIO_PIN_2_HIGH = 0x04 # Logic-high on Pin-2
MCP23017_GPIO_PIN_1_HIGH = 0x02 # Logic-high on Pin-1
MCP23017_GPIO_PIN_0_HIGH = 0x01 # Logic-high on Pin-0
MCP23017_GPIO_PIN_HIGH = 0xFF # Logic-high on All Pins
MCP23017_GPIO_PIN_LOW = 0x00 # Logic-low on All Pins
class mcp23017():
def init(self, smbus, kwargs = {}):
self.dict.update(kwargs) #set address to default if not passed
if not hasattr(self, ‘address’):
self.address = MCP23017_DEFAULT_ADDRESS
self.smbus = smbus
#we only need to know which are outputs as the chip sets all GPIOs as inputs by default for safety reasons.
if hasattr(self, 'gpio_output_map'):
bank = 0
for bank_map in self.gpio_output_map:
register_byte = 255
for channel in bank_map:
register_byte = register_byte ^ 1 << channel
if(register_byte != 255):
self.set_output_register(bank, register_byte)
bank = bank+1
def set_output_register(self, bank, register_value):
self.smbus.write_byte_data(self.address, bank, register_value)
def set_bank_status(self, bank, status_value):
self.smbus.write_byte_data(self.address, MCP23017_REG_GPIOA+bank-1, status_value)
def set_gpio_high(self, bank, target_gpio, status = None):
if(status == None):
target_byte_value = 1 << target_gpio
new_status_byte = status | target_byte_value
self.smbus.write_byte_data(self.address, MCP23017_REG_GPIOA+bank-1, new_status_byte)
#pseudo method
def turn_on_relay(self, bank, target_relay, status = None):
self.set_gpio_high(bank, target_relay, status)
def set_gpio_high_by_index(self, target_gpio):
bank = 1
while target_gpio > 7:
target_gpio = target_gpio - 8
++bank
self.set_gpio_high(bank, target_gpio)
def set_gpio_low(self, bank, target_gpio, status = None):
if(status == None):
new_status_byte = status ^ target_byte_value
#pseudo method
def turn_off_relay(self, bank, target_relay, status = None):
self.set_gpio_low(bank, target_relay, status)
def set_gpio_low_by_index(self, target_gpio):
bank = 1
bank = bank + 1
self.toggle_gpio(bank, target_gpio)
def toggle_gpio(self, bank, target_gpio):
#check if the gpio is set high
if(status & target_byte_value != 0):
self.set_gpio_low(bank, target_gpio, status)
else:
self.set_gpio_high(bank, target_gpio, status)
#pseudo method
def toggle_relay(self, bank, target_relay):
self.toggle_gpio(bank, target_relay)
def toggle_gpio_by_index(self, target_gpio):
bank = 1
++bank
def get_single_gpio_status(self, bank, target_gpio):
return (status & target_byte_value) != 0
def get_single_gpio_status_by_index(self, target_gpio):
bank = 1
++bank
self.get_single_gpio_status(bank, target_gpio)
def get_gpio_bank_status(self, bank):
def get_gpio_bank_resistor_settings(self, bank):
return self.smbus.read_byte_data(self.address, MCP23017_REG_GPPUA+bank-1)
def pull_up_gpio(self, bank, target_gpio):
status = self.get_gpio_bank_resistor_settings(bank-1)
self.smbus.write_byte_data(self.address, MCP23017_REG_GPPUA+bank-1, new_status_byte)
As Jacob suggested it sounds like the failure is on the SMBus library. Unfortunately this is outside our technical support purview since we did not develop that.
My recommendation would be to simplify your setup/code to the bare minimum required to replicate this issue and give us information we can use to replicate the failure.
