Dear,
Is it correct to think that the python codes that are coming alone on github with various of sensors can be used only with native I2C ports?
I want to test the HYT939 sensor with the python code on github using a raspberry pi, a usb to i2c converter and then using pyton to work with it.
So first there is the import smbus: I assume this for accessing the I2C bus.
But when changing this to import serial, and make a COM connection, the write data, is still in I2C i think. Correct?
HYT939 address, 0x28(40)
0x80(128) Send normal mode
bus.write_byte(0x28, 0x80)
I change bus.write to port.write, but then i get this error:
TypeError: write() takes exactly 2 arguments (3 given)
Sorry if it al sounds very strange, or not logical at all. I’m still new at this…
