I’m a little confused about compatibility between the different product lines.
Will this work with the MQTT gateway?
If not is there another pulse counter that does?
Yes, that sensor will work with The MQTT Gateway. The MQTT Gateway is compatible with all sensors in our Enterprise product line here:
