Hi, I’m wondering if there’s any plan to upgrade the ProXR Lite 900MHz to the new Digi Xbee modules, and/or if the current boards with the PRO 53B will be forward compatible with the newer modules? XR900 I believe they are. Thanks.
Hi Tim,
The ProXR board really doesn’t care what module is installed. Since that module follows the XBee pinout there is no reason you cannot install it in the board. I’m not sure we will carry them but you could purchase the board with no module, then install it yourself. You just need to make sure the baud rate of the module is 115200 to match the ProXR UART baud rate.
