Provide antenna pattern
HI,
May i know the antenna pattern for the USB modem antenna (PR55-17A)? Thanks.
BRs,
Howard
HI,
I have one more question. If I want to upgrade to a higher-gain antenna, which model would you recommend. Thanks.
Hi, attaching the antenna pattern.
Thanks. How about if I want to upgrade to a higher-gain antenna, which model would you recommend?
Howard
900mhz antenna with gain height than 3dbi.
What about this antenna? Is it suitable for use with the USB modem? Thanks.
Yes this will work… keep the cable as short as possible
