Good afternoon
A customer of ours would like to insert a wireless temperature sensor in the rotating combustion chamber of an industrial plant we made for him.
The industrial wireless thermocouple high temperature sensor https://store.ncd.io/product/industrial-wireless-thermocouple-high-temperature-sensor/ - together with the Industrial IoT Wireless to RS485 Modem https://store.ncd.io/product/industrial-iot-wireless-rs485-modem/ - seems to be suitable for such purpose.
To understand if I can establish a direct communication with the control system of the plant, I would need to know if:
- the Industrial IoT Wireless to RS485 Modem allows Profibus communication with the PLC of the plant, which is a CPU 315-2 DP ( Siemens code: 6ES7 315-2AG10-0AB0 / V2.6 ) with a CP 343-1 Lean communications processor ( Siemens code: 6GK7 343-1CX10-0XE0 / V3.0 )
- you give a setting file with .gsd extension
- there is the possibility to change the Profibus address of the device in the gateway
Thank you in advance and best regards
