My gateway and Two-Channel-Vib-V3 node are up and running! Very happy about that.
Configuration of the node setting can be done. Super.
But what I can’t do from node-red, which is running on the Gateway, is installing node-red nodes.
Not from “Manage pallette” and not from the Terminal (not in root and not in the directory .node-red).
That is not a library which NCD developed. I would recommend reaching out to the developer of the library for support. This appears to be the GitHub repo for the library:
