Hello Braskar, I’m follow these instruction and I have this result on Azure, I’m not sure if this node information are from the vibration sensor, perhaps when I trying to use NCDio Software or Vibration Sensor Software I didn’t reach the hardware.
“deviceId”: “NCD_0013A200”,
“etag”: “AAAAAAAAAAE=”,
“deviceEtag”: “ODQwNDYxNjY3”,
“status”: “enabled”,
“statusUpdateTime”: “0001-01-01T00:00:00”,
“connectionState”: “Connected”,
“lastActivityTime”: “2019-06-12T10:36:19.0178515”,
“cloudToDeviceMessageCount”: 0,
“authenticationType”: “sas”,
“x509Thumbprint”: {
“primaryThumbprint”: null,
“secondaryThumbprint”: null
“version”: 47,
“properties”: {
“desired”: {
“$metadata”: {
“$lastUpdated”: “2019-06-11T20:43:22.2648147Z”
“$version”: 1
“reported”: {
“Gateway_Config”: {
“mac”: “3C:71:BF:C2:C9:FC”,
“ip”: “172.20.17.55”,
“xbee_address”: “00:13:A2:00:41:91:49:31”,
“network_id”: “7FFF”,
“preamble”: “0”,
“tx_power”: “4”,
“xbee_ready”: true
** “nodes”: {**
** “00:13:A2:00:41:91:48:EC”: {**
** “transmission_count”: 66,**
** “battery_level”: 3.29406,**
** “type”: 40,**
** “node_id”: 0,**
** “rssi”: 100,**
** “rms_x”: 72271.36,**
** “rms_y”: 15598.07,**
** “rms_z”: 14062.08,**
** “max_x”: 0,**
** “max_y”: 42539.51,**
** “max_z”: 35750.39,**
** “min_x”: -123952.6,**
** “min_y”: -48012.81,**
** “min_z”: -37509.13,**
** “temperature”: 26**
“$metadata”: {
“$lastUpdated”: “2019-06-12T15:26:18.2940878Z”,
“Gateway_Config”: {
“mac”: {
“ip”: {
“xbee_address”: {
“network_id”: {
“preamble”: {
“tx_power”: {
“xbee_ready”: {
“nodes”: {
“$lastUpdated”: “2019-06-12T10:36:19.0022257Z”,
“transmission_count”: {
“battery_level”: {
“type”: {
“node_id”: {
“rssi”: {
“rms_x”: {
“rms_y”: {
“rms_z”: {
“max_x”: {
“max_y”: {
“max_z”: {
“min_x”: {
“min_y”: {
“min_z”: {
“temperature”: {
“$version”: 46
“capabilities”: {
“iotEdge”: false
