I am using the Enterprise Gateway with PR55-24 differential pressure sensors. I am reading the sensor data with the Node-Red installed on the gateway using msg.payload.sensor_data.pressure.
What units are these pressure values?
@Bhaskar can correct me if I’m wrong but I believe they are in Pascals.
yes the unit is of measurement is pascal
Great. Thank you!
-David
