Hello, I am looking for monitoring a processing drive (7kW, 12A, working at 18000 rpm) and its bearings and found the
Industrial IoT Wireless Predictive Maintenance Sensor (UPC: 689860069947). The data would be processed at the edge using a Industrial IoT Wireless to USB Modem (UPC: 689860069961).
Is this setup suitable?
Can multiple PM sensors be connected and read by one IoT Wireless to USB Modem?
Is the sensor sending the data continuously or is it possible to measure the signals, keep them in memory and send at a defined interval? As far as I understood in Germany it is not allowed to use the 868 MHz frequency for continuous data transmission without additional disruption mitigation techniques.
Furthermore is a drawing or documentation of the vibration and temperature sensor dimensions available?
Do you have drawings like the enclosure one for the sensor at the mounting point? I would like to validate the mounting / fitting at the machine. How long are the cables of the vibration and current sensor to the transmitter box? Thank you very much in advance.
