Greetings!
I’ve been testing this sensor with Cirrus Link MQTT broker as part of Ignition, which after some configuration works well!
When testing another MQTT broker such as vernemq the sensor consistently reboots into configuration mode after trying to save the configuration.
Main differences on this instead of a FQDN as the connections we are connecting right to an IP/port. The vernemq broker has no authentication setup as well.
I’m a previous most about the micro gateway I suspect it is most certainly a configuration issue on my end causing the sensor to continuously reboot into setup. I however have verified via MQTT.fx that I can sub/pub on the targeted broker.
I haven’t checked for any new firmware in about a month and I can check again. Is there something slightly different about this sensor compared to the others?
Thanks!
~J
