I have received a new batch of NCD hardware, and when I was configuring the 3-Wire RTD Sensors I noticed that not a single one is communicating with the modem.
I started doing some hardware switches, with some sensors from a previous order and I have the following conclusions:
1 - New hardware radio module (SX 868) works on the old sensor board
2 - New hardware board doesn’t work at all
3 - After I had a radio module working on an old board, tested it in the new board, it doesn’t work anymore on the old board…it requires that I flash the profile again to work on the old board.
4 - The old and new sensor boards are the “same” (WSA_MAX31865).
5 - The new boards have 3.2V across pins 1 and 10.
What can I do more to debug the issue?
Thanks in advance.
