PR55-22 module and TLRx relay controller
I have TLR15 Taralist relay board with the PR55-22 WiFi communications module. Everything working great, BUT I need to mount this in a steel box that is shielding the WiFi connectivity. Is there a compatible version of this communications module that will provide a connector for an external antenna, IE: SMA, RP-SMA, MHF4, or U.FL/IPEX connector? The box alreaady has a suitable WiFi antenna mounted on it.
Unfortunately this is a relatively new WiFi module to us and we do not yet offer an external antenna version of it.
If at all possible I would recommend mounting it in a plastic enclosure instead.
Travis-
It looks like generic RN-XV WiFly modules are still obtainable from elsewhere on the internet. Some versions of these have RP-SMA connectors for external antennas. Would one of those work plugged in the TLR15 Taralist board in place of the PR55-22 module without any extraordinary software gymnastics? Its a long story, but I’m kind of stuck with the steel box for a particular outdoor installation.
Thanks.
Absolutely. You will however need to configure that module for your application which will require an XBee to USB adapter which can be purchased here:
The main thing is you will need to set the module’s serial interface baud rate to 115200.
If you have any other questions please let me know.
