I have a PR55-17A Wireless USB Modem and a PR52-33TS Tilt Sensor. I can use Alpha Station to see serial communication with the USB modem to receive sensor readings.
I’d like to develop LabVIEW code to receive data from the sensor. Where can I find information on decoding the serial data or even query the sensor for data on command?
Thanks Bhaskar, this was exactly what I was looking for. Actually got a parser working to make sense of the serial data being received. Yay!
Is there a way to continually get data from the sensor? In playing around with the serial communication and configuring the sensor through Alpha Station, the fastest I can get data from the tilt sensor seems to be about a reading every 1.3 seconds. What’s the fastest that the tilt sensor can stream data out?
