I believe I am assuming correctly but want to run this by you guys.
I will be using the PR33-8 to connect Qty 01, pressure transducer, 4-20mA, 10-30VDC.
I assume I will be able to use the Onboard 16V Voltage Supply (Boosted from 5V) of the PR33-8 and will NOT need to externally loop power the transducer.
If this is the case, can someone show me what pins on the PR33-8 I need to connect my 2-wire transducer to.
Thank you very much.
