I was trying to put together a PR32-17 Rev.B key fob receiver for my onion omega2+, with the PR32-4 shield. Somehow the receiver does not fit together (the IC on the bottom side blocked by the Omega2+). Does anyone experience the same issue? Is there any way to fix? Thanks
I believe there should be riser pins that prop the Key Fob overlay up higher so it does not hit the top of the Onion. Can you provide a photo?
The key fob receiver comes with 1 layer of riser pins but still it’s not rising it enough. I have to add another layer to make it works. I don’t have a photo now but I’ll upload one when I find a chance.
