kstokes
#1
I tried adding a terminal connection on the Gauge and Pressure Sensor, but having trouble with powering it with that.
My multimeter shows 12V over the two terminals I added.
In either switch position I don’t receive any transmissions.
If I add the batteries back in, and flip the switch, I receive transmissions.
Are there any other test points I can check with my multimeter?
Is the terminal I attached in the wrong spot perhaps?
Is there another spot I can use for powering this sensor?
Bhaskar
#2
in the product line we have to add an extra power circuit in order to support external power supply.
the extra power circuit gets installed in the 3 holes near CB marking.
we can send you a couple of the power supply boards if you are planning to use with external power supply.
