What products should work fine if I want to control 15 pneumatic solenoid driven valves in parallel at the same time but indepently, valves are normally closed and will be trigered by pulses(up to 6 pulses per second) that should allow the valves to open for a brief time (from 50-165ms per pulse) accurately using phyton code(real time video analisis), the solenids on these pneumatic valves are available in different configurations: 12VDC 5W , 24VDC ??W, 110VAC & 230VAC. Firstly I want to control an NCD device with a rapberry pi 3b+ if possible, then go with a PC, I know that induction tipe loads and very high triggering frecuencies point to SSR’S with snubber and flyback diodes arangements or maybe FET´S?.
