I have MPU-6000 sensor that I need to have about 12 feet from my RaspPi. I am using P82B715TD to extend the IC2, however I am running into an issue.
When I plug the MPU-6000 directly into my IC2 interface on the PI, I am able to run the sample code.
When I plug through the extender I get:
File “test_gyro.py”, line 18, in
bus.write_byte_data(0x68, 0x1B, 0x18)
File “/usr/local/lib/python3.5/dist-packages/smbus/util.py”, line 59, in validator
return fn(*args, **kwdefaults)
File “/usr/local/lib/python3.5/dist-packages/smbus/smbus.py”, line 145, in write_byte_data
raise IOError(ffi.errno)
OSError: 121
So a few questions:
Does my smbus address stay the same with an extender? or do I need to use a different bus address when going through an extender?
Here is my physical layout, am I doing something wrong here?
I have a Power supply of 19 volts (the extender supports this), I have a 4 wire connection extended piece, Red, black, green, yellow. This is not the same as the premade 4 wires cables.
From the PI I have the 4 wire connector that came with the sensor plugged into the Extender TX side. Then from Extender TX, I have a 19 volt DC plugged into the barrel connector on the TX, From here I have the Red wire in the 4 wire extended wire also plugged into the + on the barrel plug. On the TX side I have G on the Black, 1 is the Green wire, and 2 is the Yellow wire. The TX has a red LED that is lit.
Ok the 4 wire connector connects to the RX side of the extend. Green is plugged into 1, Yellow into 2, Black into G and R goes to a barrel connector (no ground on the barrel connector as I tested the G and the minus on the Barrel is the same) So at this point, the standard four wire connector goes from the RX extender to the MPU-6000 “in” At this point, all of the pieces have a RED light on, so I think Power is ok? Am I missing something big here?
Any advice would be helpful!
John
