Can someone please confirm if it is possible to have one sensor connected to two Mega modems?
I would like to set up a system where two operators can monitor/receive an output of single Type K temperature sensor output using two separate Mega modems. Both operators are sitting 100m away.
Does this method interfere with the Temperature sensor output value?
If you have better solution, please suggest.
