Not able to log into NCD board MIRCC1
I am not able to log into the browser for config settings. The board shows up in NCD Base Station but no luck logging into it. I was able to change the IP using NCD config tool but want to find out why im not able to log on to it with the browser.?
It could be a few issues. Primarily if there was an IP address conflict where two devices have the same IP address this could happen.
If there was a networking error where the ethernet module was not assigned an IP address via DHCP or was assigned an IP address outside of the subnet mask of your PC’s network.
