Is it possible to use the “Wireless 4-Channel IoT Relay Controller 10-Amp endNode” with Node-Red? If yes, do you have a demo flow that shows how the relays can be activated with Node-Red?
If not, how can this component be used with a 900 MHZ wireless modem?
