Did a search of the forum and website and can’t find what I need. I need a schematic for your R41DPDTCNRS relay board. I have everything I need but can’t find the relay terminal block pinouts. It’s two 12 pin stacked blocks
You can find the schematic at: https://docs.google.com/drawings/d/e/2PACX-1vRzygsyGUdlFJYl1E_2F-EF1RFy6hbAuHXQDEg1IVhv0NinpEW5DP4hI0ad4awoSke9mfdQ487NOjNH/pub?w=1456&h=578&1531940844
or under the resources tab of the product at: https://store.ncd.io/product/rs-232-4-channel-dpdt-relay-controller-with-serial-interface/
Let me know if you need any clarification.
Thank you Jacob for the information, had trouble finding it through the website. Just a little clarification, there are no ref designators silk screened on the relay footprints, should I assume LED K1 corresponds to relay 0 on the terminal block? K1=0, K2=1, etc…
Yes, K1 will represent Relay 0 (the first relay) and K2 will represent Relay 1 (the second relay) etc.
