Yesterday I received my One Channel 0-10V DAC I2C Digital To Analog Converter and I2C Shield for Raspberry Pi. In a matter of an hour, I had everything up and running. It was really straightforward. I hooked up a multimeter and watched the voltage change as my python program ran. Very satisfying to get that part to work.
However, it turns out that the proportional solenoid valve I’m trying to control is not responding because the current is insufficient. I should have known this. My measurements show no more than 90 mA coming from the DCA out. What I need is 200 to 500 mA. What is the easiest way for me to achieve that goal? Can I leverage the DCA I currently have and somehow add an amplifier? Or is there a ready-made board that will do what i need? The pi is limited to 5V, so it seems to me that an amp will be necessary.
Anil,
That would be ideal, to have you produce a bundled solution. We will definitely require more than 10 pieces. What do I need to do to get that process started?
