Hello Everyone, I’m new to this community.
I was looking for wireless CO2 sensors and found NCD products. I have a question with regards to the maximum number of remote devices a Gateway can connect to. We need to install 40 or so CO2 sensors, and we are planning on having them talking to the NCD Micro Gateway (MQTT) and then sending the data to our cloud MQTT broker. While reading the description of the gateway I found this:
“In Run mode (daily use), the NCD Micro Gateway will work with as many IoT sensors as memory will allow (estimated to be greater than 20, but we did not set a hard limit).”
It mentions “greater than 20” but does not give an exact number, would 40~50 sensors be ok on one Gateway? if not, can we have two gateways working together? would there be any issues with end device configuration if there are more than one?
Thanks!
Enveze
