I have Environmental sensor which is sending data every 11 minutes. I don’t have Labview. I need to do that with XCTU or by sending AT command from other Xbee. Can you help me to configure the delay.
Thanks.
Thanks.
We also have alpha station which can be used to change the delay.
If you want to use XCTU than i will recommend checking out this guide
I was exactly looking for this solution. Thank you.
Expected data frame when entering configuration mode as per document is 7E 00 1C 90 00 13 A2 00 41 91 1B 83 FF FE C2 7A 00 00 00 23 00 00 50 47 4D 00 00 00 00 00 00 0A
But I am getting 7E 00 1E 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 7A 00 00 00 1B 00 00 50 47 4D 00 00 00 00 00 00 7B
Frame type doesn’ t match. What does this mean?
