My company is incorporating these devices into some of our products, and I’ve just received my first development instance in order to adapt our software. Before getting into any code, I want to demonstrate control of the relays manually.
From what I can tell (the documentation seems to be spread around a bit) I need to let this acquire an IP address via DHCP and then connect to that address using NCD Base. The first part seems to work - using Wireshark I can see it doing a DHCP request and being assigned an address, and pinging that address gets a response. However, I never see it appear in “Discovered Network Devices” in NCD Base, and if I specify the address in the “Network” section and then click OK, the resulting window says “Device Identification Failed”.
What now?
