MQTT Wiring Diagram
I can see the wire labels on the MQTT drawings and need a little clarification. How does input 1 or 2 switch on to send a push notification. Is it when the 3v closes to it, or when the ground closes to it? Attached is the device.
If I remember correctly if you are monitoring a dry contact then a push notification will be sent when you connect the input to 3.3VDC so wire one side of your dry contact to the input and the other to the 3.3VDC line. I’m pretty sure that’s correct but if not switch over to GND. You won’t damage anything.
Travis
