I connected my gateway to my wifi and broker everything is working, but I would like to be able to change some settings because the sensor is not sending fast enough. My problem is that I can’t seem to be able to connect to the gateway with alpha station.
The PC with alpha station is on the same network
I do receive data on the broker (sometimes)
I can access some settings with my phone by putting the gateway in config mode
Tank you very much, I have been looking a lot for a page exactly like this. It will work for what I want to do.
But do you know if is possible to use the alpha station at all with the micro gateway mqtt because the interface is a lot better.
thanks again
No, the MQTT Gateway is not compatible with Alpha Station at this time.
It is, however, possible to flash Mega Modem firmware onto your MQTT Gateway, connect it to Alpha Station as a Mega Modem, configure the sensors, then flash it back to MQTT Gateway firmware after you are don configuring the sensors. Documentation on flashing different firmware to your MQTT Gateway can be found here:
