While compiling the program, I get the following errors:
Can you help with the solution?
Regards;
Zafer UNLU
Arduino:1.8.13 (Windows 10), Kart:“Arduino Uno”
libraries\Wire\Wire.cpp.o (symbol from plugin): In function `TwoWire::available()’:
(.text+0x0): multiple definition of `TwoWire::available()’
sketch\Wire.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `TwoWire::rxBufferLength’
(.text+0x0): multiple definition of `TwoWire::rxBufferIndex’
(.text+0x0): multiple definition of `TwoWire::read()’
(.text+0x0): multiple definition of `TwoWire::rxBuffer’
(.text+0x0): multiple definition of `TwoWire::peek()’
(.text+0x0): multiple definition of `TwoWire::flush()’
(.text+0x0): multiple definition of `TwoWire::onReceiveService(unsigned char*, int)’
(.text+0x0): multiple definition of `TwoWire::user_onReceive’
(.text+0x0): multiple definition of `TwoWire::onRequestService()’
(.text+0x0): multiple definition of `TwoWire::user_onRequest’
(.text+0x0): multiple definition of `TwoWire::txBufferIndex’
(.text+0x0): multiple definition of `TwoWire::txBufferLength’
(.text+0x0): multiple definition of `Wire’
(.text+0x0): multiple definition of `TwoWire::write(unsigned char)’
(.text+0x0): multiple definition of `TwoWire::transmitting’
(.text+0x0): multiple definition of `TwoWire::txBuffer’
(.text+0x0): multiple definition of `TwoWire::write(unsigned char const*, unsigned int)’
(.text+0x0): multiple definition of `TwoWire::TwoWire()’
(.text+0x0): multiple definition of `TwoWire::begin()’
(.text+0x0): multiple definition of `TwoWire::begin(unsigned char)’
(.text+0x0): multiple definition of `TwoWire::begin(int)’
(.text+0x0): multiple definition of `TwoWire::beginTransmission(unsigned char)’
(.text+0x0): multiple definition of `TwoWire::txAddress’
(.text+0x0): multiple definition of `TwoWire::beginTransmission(int)’
(.text+0x0): multiple definition of `TwoWire::endTransmission(unsigned char)’
(.text+0x0): multiple definition of `TwoWire::requestFrom(unsigned char, unsigned char, unsigned char)’
(.text+0x0): multiple definition of `TwoWire::requestFrom(unsigned char, unsigned char)’
(.text+0x0): multiple definition of `TwoWire::requestFrom(int, int)’
(.text+0x0): multiple definition of `TwoWire::requestFrom(int, int, int)’
(.text+0x0): multiple definition of `TwoWire::endTransmission()’
(.text+0x0): multiple definition of `TwoWire::onReceive(void (*)(int))’
(.text+0x0): multiple definition of `TwoWire::onRequest(void (*)())’
libraries\ADC121C_MQ131_Example\ADC121C_MQ131.cpp.o (symbol from plugin): In function `ADC121C_MQ131::getAddr_ADC121C_MQ131(unsigned char)’:
(.text+0x0): multiple definition of `ADC121C_MQ131::getAddr_ADC121C_MQ131(unsigned char)’
sketch\ADC121C_MQ131.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `ADC121C_MQ131::begin()’
(.text+0x0): multiple definition of `ADC121C_MQ131::alertLowTriggered()’
(.text+0x0): multiple definition of `ADC121C_MQ131::alertHighTriggered()’
(.text+0x0): multiple definition of `ADC121C_MQ131::setCycleTime(ADC121C_MQ131CycleTime_t)’
(.text+0x0): multiple definition of `ADC121C_MQ131::getCycleTime()’
(.text+0x0): multiple definition of `ADC121C_MQ131::setAlertHold(ADC121C_MQ131AlertHold_t)’
(.text+0x0): multiple definition of `ADC121C_MQ131::getAlertHold()’
(.text+0x0): multiple definition of `ADC121C_MQ131::setAlertFlag(ADC121C_MQ131AlertFlag_t)’
(.text+0x0): multiple definition of `ADC121C_MQ131::getAlertFlag()’
(.text+0x0): multiple definition of `ADC121C_MQ131::setAlertPin(ADC121C_MQ131AlertPin_t)’
(.text+0x0): multiple definition of `ADC121C_MQ131::getAlertPin()’
(.text+0x0): multiple definition of `ADC121C_MQ131::setPolarity(ADC121C_MQ131Polarity_t)’
(.text+0x0): multiple definition of `ADC121C_MQ131::getPolarity()’
(.text+0x0): multiple definition of `ADC121C_MQ131::Calibration(float)’
(.text+0x0): multiple definition of `ADC121C_MQ131::Measure_Resistance(int)’
(.text+0x0): multiple definition of `ADC121C_MQ131::clearAlertStatus()’
(.text+0x0): multiple definition of `ADC121C_MQ131::setAlertLowLimit(unsigned int)’
(.text+0x0): multiple definition of `ADC121C_MQ131::setAlertHighLimit(unsigned int)’
(.text+0x0): multiple definition of `ADC121C_MQ131::setHysteresis(unsigned int)’
(.text+0x0): multiple definition of `ADC121C_MQ131::clearLowestConversion()’
(.text+0x0): multiple definition of `ADC121C_MQ131::clearHighestConversion()’
(.text+0x0): multiple definition of `ADC121C_MQ131::getLowestConversion()’
(.text+0x0): multiple definition of `ADC121C_MQ131::getHighestConversion()’
(.text+0x0): multiple definition of `ADC121C_MQ131::Measure_Voltage()’
(.text+0x0): multiple definition of `ADC121C_MQ131::Calibration()’
(.text+0x0): multiple definition of `ADC121C_MQ131::Measure_Rs()’
(.text+0x0): multiple definition of `ADC121C_MQ131::Measure_RatioRsRo()’
(.text+0x0): multiple definition of `ADC121C_MQ131::Measure_Scaled(float, float)’
(.text+0x0): multiple definition of `ADC121C_MQ131::Measure_Ozone(float, float)’
(.text+0x0): multiple definition of `ADC121C_MQ131::getAlertStatus()’
libraries\ADC121C_MQ131_Example\Wire.cpp.o (symbol from plugin): In function `TwoWire::available()’:
libraries\ADC121C_MQ131_Example\utility\twi.c.o (symbol from plugin): In function `twi_init’:
(.text+0x0): multiple definition of `twi_init’
libraries\Wire\utility\twi.c.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `twi_setAddress’
(.text+0x0): multiple definition of `twi_readFrom’
(.text+0x0): multiple definition of `twi_writeTo’
(.text+0x0): multiple definition of `twi_transmit’
(.text+0x0): multiple definition of `twi_attachSlaveRxEvent’
(.text+0x0): multiple definition of `twi_attachSlaveTxEvent’
(.text+0x0): multiple definition of `twi_reply’
(.text+0x0): multiple definition of `twi_stop’
(.text+0x0): multiple definition of `twi_releaseBus’
(.text+0x0): multiple definition of `__vector_24’
libraries\utility\twi.c.o (symbol from plugin): In function `twi_init’:
collect2.exe: error: ld returned 1 exit status
“Wire.h” için birden fazla library bulundu
Kullanılıyor: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Kullanılmıyor: C:\Program Files (x86)\Arduino\libraries\Wire
Kullanılmıyor: C:\Program Files (x86)\Arduino\libraries\ADC121C_MQ131_Example
“ADC121C_MQ131.h” için birden fazla library bulundu
Kullanılıyor: C:\Program Files (x86)\Arduino\libraries\ADC121C_MQ131_Example
Kullanılmıyor: C:\Program Files (x86)\Arduino\libraries\Arduino_Library_MQ131_Ozone_Gas_Detection_Sensor-master
exit status 1
Arduino Uno kartı için derleme hatası.
C:\Program Files (x86)\Arduino\libraries\ADC121C_MQ131 içerisinde geçersiz kütüphane bulundu: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\ADC121C_MQ131
C:\Program Files (x86)\Arduino\libraries\ADC121C_MQ131-master içerisinde geçersiz kütüphane bulundu: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\ADC121C_MQ131-master
C:\Program Files (x86)\Arduino\libraries\examples içerisinde geçersiz kütüphane bulundu: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\examples
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences."
