Hello there. I have a client who has the MIRCR4X installed controlling their water tank pumps. They would like to get their level transmitted down to the plant using as well. I was wondering if you had boards set up that would transmit and receive the 4 relays as well as one analog input for a 4-20 mA signal. Thank you.
Do you want to control these relays using a computer or push buttons ?
The relays are controlled by a PD6000 Process Meter which is getting its input from a pressure transmitter.
