I have a set of IP contacts that I have configured per the quick start guide. It is my understanding that if configured properly, when I short the “Contact Closure Input” on the first board, the contact on the 2nd board should change states. However, nothing is happening when I short the input on the first board. Any suggestions?
Change the local port setting on the TCP Server Device to 5000 and it should work.
Let us know if you need anything else.
The baudrate should be 115200.
That worked! Thank you
No problem. Let us know if you need anything else.
