I am planning to measure the turns of a DC brushed motor and would like to buy a Hall sensor with a mini module. The motor has the following characteristics:
12V DC / 3300rpm / Tmax 1,8Nm / 4 brush.
A disc magnet S-03-02-N is to be fixed eccentrically to the front face of the motor shaft using magnetic force. The sensor should be glued to the housing. I have the following questions for you:
- on the pictures in the ncd.Store I can only see the mini module. Is the Hall sensor included in the delivery or do I have to buy it separately? Do you offer the sensor separately?
- you offer sensitivities from 0,5mv/G to 9mv/G? Which sensitivity do you recommend for my application.
- is it also possible to measure speed with the sensor?
- will the Hall sensor be damaged by superglue?
Thank you very much for your support!
