Hi I’d like to use one of these pulse counter sensors and connect it to a micro gateway like this one and have it transmit tha data to an MQTT broker (mosquitto), although the specs of the sensor says this is doable I can’t seem to find an MQTT micro gateway. Would the microsoft azure / AWS gateway work?
Thank you
Unfortunately our MQTT micro-gateway is still in development. It should be finished within the month.
If you need a quick fix and have a computer on-site you could use Node-Red to publish and subscribe to sundry MQTT servers. It works fantastically.
The MQTT gateway is just about ready, hardware, guide, and photos are done now. Just needs final entry into our web site. I am hoping to finish this in the next few days.
