I am working on planning out a solution on a 28V DC system and I need to be able to measure the current in AMPs on several circuits and the system can go up to 28.3V. I am looking at implementing this with a Raspberry PI 4. What options do I have? Would the 8-Channel DC Current Monitor with I2C Interface work?
yes this configuration you purposed will work.
We recommend getting an I2C shield to interface ncd board with i2c devices.
Thank
So the 8-Channel DC Current Monitor with I2C Interface can handle up to 29V?
Yes, it will work with 29V load.
Out of curiosity, what is the max input voltage?
the max load capacity is 200Watt.
in terms of voltage max 180V.
max current 5Amp.
