I have a couple of feature requests for your enterprise hardware line - hopefully these are things you’ll consider adding.
It would be very useful if the MAC Address of the various sensor modules was accessible without having to remove the Xbee chip from the module e.g., as a sticker on the back of the sensor.
When the sensor powers up it sends a RUN message. the message looks like this
7E 00 1C 90 00 13 A2 00 41 81 50 E9 FF FE C2 7A 00 00 00 07 00 00 52 55 4E 00 00 00 00 00 00 8A
Over here the mac address is 00 13 A2 00 41 81 50 E9
The sensor also sends this message when user hits the reset button.
We will add a sticker as well
Excellent suggestion,. Just created a profile. Our PID is 0x7BCD.
Wow - that’s great news, thanks so much Bhaskar - I’m impressed by your excellent customer support!
I have a couple of follow-up questions for you:
Can you please give us your FT_Program “Template” (XML file) so that we can flash our existing NCD devices to match the future devices that will use your new PID?
Do you know when the new MAC address stickers will be available? Is that something we should request when we make our next order?
Hi Cormac,
please hold on the ftdi PID update. it looks like the device is not registering as com port after the update. It requires a change in ftdi driver .inf file as well.
Once i finalize the testing i will update the profile.
Update : I updated the .inf files but it needs to be approved by FTDI. I wrote them. once they approve the driver w should be good to go.
Hi Cormac,
Looks like this wasn’t as straight forward as i thought. We will need to edit the drivers and will need to certify the drivers. FTDI also mentioned that we will need to maintain the drivers as well.
This might work in windows case but things get more complicated when it comes to MAC and linux. Users will need to update driver files ( manually on individual basis). it might create more problems than solving.
ps. from today onwards all enterprise products will be shipped with MAC address stickers.
Hi Bhaskar, thanks for the update - that’s great about the MAC stickers!
If it’s helpful, when we were testing internally we only renamed the device string rather than the PID/VID, which meant that we didn’t need to update the drivers. Any chance you could use the default PID/VID? That would be really helpful since we only need the device description string to be unique to NCD.
Cormac,
I am doing something similar as well. I kept the PID/VID same and changed the manufacture name to “ncd.io”
and product description to “ncd.io wireless modem”.
We can definitely do this for all the users as well.
