We are using your IOT-capable offboard 95% accuracy 4-channel AC ammeter board. Are there any issues with splicing in additional wire of the same gauge to lengthen the cable between the clamping sensor and the screw terminals on the PCB? For example, would we need to multiply amperage readings by a correction factor?
Thanks!
How much are you looking to extend the CT cables?
Sorry for the late reply - I didn’t get notification of yours!
We’d be extending by at most another 7’, so to a total of 12’.
@Bhaskar would extending the cable of the CT to 12 feet have any significant impact on the accuracy of the sensor?
Yes, it will be fine.
