Is a pinout of the KFX Receiver module available anywhere?
More specifically, I am trying to determine:
Is the communications interface standard UART/RS-232?
If so, which pins are the UART RX/TX?
What is the default baud rate/parity, and can it be changed?
Which pins are VCC/GND?
What is the input voltage range for VCC and what is the typical current draw of the module?
Thanks!
