I have a KFX controlled 2 channel board. My intended use is to momentarily toggle relay 1 as an up function on a hoist and toggle 2 for the down command. After configuring the KFX and the 2-button fob’s; I am only able to get relay one to respond as desired. When pushing button 2 on the fob the led on the KFX lights, however relay-2 does not receive/respond to button push.
I reviewed the KFX quick start guide and went over the configuration, and believe i have it configured correctly. Any suggestions appreciated.
