Key fob module is mounted to zigmo base. USB light is ON.
Followed steps on https://ncd.io/kfx-key-fob-communications-module-quick-start-guide/
Remote learned 1 button.
Plugged in USB to Zigmo
Pushed “Learn”, pushed button on remote and “Learn” again.
Then opened NCD Base program that I downloaded from link provided in instructions.
Selected COM3 - USB (I can see it in my devices on my computer)
When I click ok it pops up a window that says it couldn’t connect with the provided BAUD rate (I have it set to 115.2K as per instructions). It cylces through available BAUD rates then disconnects.
I’m using windows 10. Any help is appreciated.
