I have an application where I would like to have a few keyfobs but also have a set of hardwired switches to control the same relays. Is this doable?
Can you describe how you would like the key fob and inputs to control the relays?
I want to control some lighting contactors. There will be operators on the plant floor that need to turn off zones of lighting using keyfob remotes. They also want to control the lighting zones from a central switching location. I would most likely use monentary switches for that. Can the relays be programmed as latching relays that cycle on a button press?
