I recently received an AWS Gateway and a 2-channel vibration v3 sensor for use on a project. I’ve been able to configure both to the settings I want and as far as I can tell both seem to be working as individuals.
However, the sensor and the Gateway are having trouble communicating with one another. Even though both are on and sending out info, no data is being uploaded to AWS. I’ve checked the gateway settings and the gateway is able to identify the sensor but I don’t think it’s picking up the vibration information.
I’ve checked in node-red and I know the sensor is working and sampling data at the 1-minute rate I set it to and when I used an older 1-channel v3 vibration sensor with the gateway the data was able to be uploaded without any issue.
I’m not sure what else I should try so any help is really appreciated.
Thanks!
