… in automotive and marine environment? Meaning, will the power supply protect/handle typical transients and dropouts (voltage drop when starter is operated) situations? Thanks
the on board power supply voltage range is 6V-22V, so it will work fine if the voltage drops below 12V.
What about handling of transients typical in an automotive environment?
This is what I’m asking …
Source document … http://www.industrologic.com/autoelectronics.pdf
I suspect the answer is no, the PR35-20 is not able to handle this. Yes/no?
We have had customers use our products with the same power electronics in automotive applications many times without problems. Nevertheless, the extreme voltages present in Automotive supplies may eventually cause damage. Power conditioning is advised for high reliability applications.
