Hi NCD,
I recently purchased an Iot Edge Gateway. i set it and it worked. i was able to view NodeRed, etc.
However, last friday , i see the stat light and 3v3 light are red .I cant acces the gateway and the oled led is off.
Wondering what may have happened, and what to do. I tried rebooting it a few times, but the problem persists. Wondering if here is anything to do, other than to perhaps try and do a factory reset?
Thanks!
connect to the gateway over softAP and open webpage.
thanks for reply
i can’t find wireless signal from iot edge gatweway
can you try a different 12V 1Amp power supply
Okey stat light just changed to green but cant find wireless signal. what should i do ?
does the LOED has any info on it.
if not i will recommend reflashing the firmware. instruction can be found in product manual.
thanks for help, i’ll try it
can you tell me how to reflashing the firmware with windos 10 ?
if you are using windows use putty as your terminal
