Hi NCD,
I recently purchased an IoT Edge Gateway. I set it up last night, and it was super easy and worked great to connect to my Wifi. I was able to view NodeRed, etc.
However, this morning, I see the Wifi and Ethernet Connection is Down (as per the LCD), and I cannot find the ad-hoc wifi name to access the gateway and set it up again. It also doesn’t seem to work on Ethernet.
Wondering what may have happened, and what to do. I tried rebooting it a few times, but the problem persists. Wondering if here is anything to do, other than to perhaps try and do a factory reset?
Thanks!
