IoT Edge Computer Unable Shutdown AP
Hello, I have two Iot Edge Computers, both of which have their AP enabled by default. I am attempting to disable the AP but when I attempt to issue the shutdown command via clicking the “AP-STATE” and submitting the shutdown AP command, I get the following error in response as a browser alert.
Bad Gateway
'The process did not produce any response”
The device is connected via ethernet, the shutdown command results in the same error whether I connect to the system config page via the DHCP address or the AP address.
You can do this from the terminal as explained here:
