Is there an ability to integrate and control with Stringify?
We don’t have anything that will work with them out of the box, it looks like its possible to write your own Node.js to talk to their service, but I’m not sure how open it is: https://www.stringify.com/app/uploads/2017/06/Node-Developer-Module-Technical-Doc-rev-03.pdf
Ideally they would support MQTT so you could just use their Maker flows (https://search.stringify.com/things/fEKBTcS1iCb3F99yGsNpV9svvetMzGwG_1) to update and monitor an MQTT topic.
You might ask on their forum as I’m sure someone using that platform has connected the service to an Arduino or equivalent at some point.
