I tried to follow the instruction given in the documentation, unfortunately i could get it work with SerilaPort1, but when i tried using the sample, the hardware is working with any issues
Should I use the component “NCDComponent.dll” all the time ? can I make my own code to communicate using SerialPort1 from .NET framework
If anyone have a sample for managing Relay Module without NCDComponent.dll let me know
Thank you
ProXR.pdf (2.7 MB)
provided
jacob
May 8, 2019, 3:09pm
#2
I don’t have any samples in .net without using the NCDComponent.dll, but you shouldn’t need to use it if you don’t prefer to.
To control the boards you simply open a serial port or a TCP socket to them and start sending commands and reading responses.
The NCDComponent just simplifies the implementation a bit.
Hello Jacob,
Thanks for reply,
Any simple code will help
i gave a very simple code
SerialPort1.Writeline(Chr(254))
SerialPort1.Writeline(Chr(27))
SerialPort1.Writeline(Chr(8))
I did not receive any response in DataReceived event and Relay 1 was not getting on.
Could you please tell me what should the serialport settings?
Awaiting your reply
jacob
May 9, 2019, 5:48pm
#4
Ah, I just noticed you had posted an old proxr guide. The new guide is at: https://ncd.io/proxr-quick-start-guide/
The newest version of the ProXR boards use an optional API wrapper that speeds up communications and reduces communication errors.
Try sending:
SerialPort1.Writeline(Chr(170))
SerialPort1.Writeline(Chr(4))
SerialPort1.Writeline(Chr(140))
SerialPort1.Writeline(Chr(0))
SerialPort1.Writeline(Chr(1))
SerialPort1.Writeline(Chr(57))
That is the command to turn all relays off in bank 1
To turn all relays on in bank 1 you can use this:
SerialPort1.Writeline(Chr(255))
SerialPort1.Writeline(Chr(56))
