I received the IoT Wireless CO2 Temperature Humidity Sensor and started working to configure it to send on minute intervals. In the beginning, the sensor run by sending data at 10 second intervals. I started playing with the configuration but unfortunately, I was unable to configure it as I needed. The sensor now is set to send data at about 30 minutes intervals and cannot change it. There are 2 red buttons on the sensor board. One of them pushes the data from the sensor while the other one for resetting the sensor. I used the second button to reset the sensor to factory settings but it did not work.
Any suggestions, please!
Thank you
