I’m sorry if my question seems trivial but I couldn’t find the answer on your site. I bought several ‘Industrial IoT Wireless 2 Channel Vibration Temperature Sensor V3’ and now I need to configure them. Could you please tell me which software to use? I assume it is one of the versions of Node-red flows. Which one? The Github link would be appreciated. Also, could you tell me which NodeId is assigned for each channel by default? 0 and 1? So I guess I have to use two configuration nodes in Node-Red? One for each channel?
Thanks in advance
